MDS won't shut off even with 1r13 !!! Charger R/T '13
Posted: Fri Sep 19, 2014 12:33 am
by nescafe4all
Hello
I'm trying to disable MDS across the tunes available but it doesn't at all
i tried 91, 93 and even modifying the stock one
i would like to get an update for my trinity rather than modifying the tune it self
Re: MDS won't shut off even with 1r13 !!! Charger R/T '13
Posted: Fri Sep 19, 2014 8:48 am
what makes you think it is not disabling?
Posted: Fri Sep 19, 2014 10:59 am
by nescafe4all
i have straight pipes and it is noticeable.
i have to kick autostick in order to shut that noisy exhaust sound and yes i can recognise the difference
even fuel consumption gauge changed quickly once MDS is activated
aren't those cases indicate that MDS is on ???
regards
Posted: Fri Sep 19, 2014 11:04 am
so you set it to off in the tune, then loaded that tune to the truck?
Post a copy of the last tune written please.
Posted: Fri Sep 19, 2014 3:41 pm
by nescafe4all
just modified the stock tune for many things including MDS
Posted: Fri Sep 19, 2014 3:42 pm
by nescafe4all
i forget to mention an issue for Fan setting. it used to work well but not it doesn't !!!
Posted: Fri Sep 19, 2014 4:26 pm
by johan
we will fix that up, attached file has fans dropped and mds off
Posted: Sat Sep 20, 2014 2:48 am
by nescafe4all
thancx Jhoan i appreciate your help
where did you discover the problem ?
because i'm planning to install 93 oct tune later as i have CAI, but not now. i have to clean the intake manifold before
Posted: Sat Sep 20, 2014 11:46 am
by nescafe4all
I pluged my trinity and been updated to 1r13a
Then u sent the tune that Johan made and i wrote it on the car
MDS still kicks on + fans started at 210 f with AC on while parking in my garage
But while cruising around at 60 MPH the coolant temp dropped to 195 F !!!!!!
I installed the tune straight away without any modification to the parameters, because as far as i believe it looks like a custom tune which i can do nothing to it
Posted: Mon Sep 22, 2014 11:27 am
nescafe4all wrote:I pluged my trinity and been updated to 1r13a
please export the last tune written and post it up here.
