Update unsuccessfull
General Trinity Support
mesanchez23677
Post by mesanchez23677 »
i have a 2014 Dodge Challenger rt and while installing the tune in my car, it tells me to turn off the ignition and turn back on. After I try to turn it on the car doesn't start. Then a message pops up saying calibration unsuccessful, calibration update via Dsdl. I try to plug it back in to the computer and it stays stuck on that screen. I was able to reset the car and get it running again.
Re: Update unsuccessfull
pop the button out and use the key, it will go much smoother :)
mesanchez23677
From the research I've done it seems you can't start the car with the emergency key. The ignition port to it doesn't pop out. Unless you know something I don't?
mesanchez23677
Well I've found out how to pop it off. Thanks for the help and quick response.
good deal.
Use the key anytime you are programming, otherwise the button is fine :)
Return to “General Trinity”
