2011 tune on 2014 stang
budlun
Post by budlun »
I still have the dynotune that was done at Delray Beach to my 2011 5.0 on my computer. I have updated the Trinity just a few minutes ago. Everything went as it should it said download successful. When I loaded my dynotune to the T1000 it asks for original backup and it is the same calid as my 2011 mustang. Since I had my car tuned on the dyno at Delray Beach the tune I got there became my original backup. is it ok to use it when I load the dynotune into the T1000? It always asks for the original backup when I load the custom tune to the T1000. It gives me the 2011 calid when I load the dynotune or what I'm calling the custom tune. It loads fine on the T1000 except I got one error screen but somehow it loaded successfully. I'm just scared to download it to my new car, because it has a different calid from my 2014. Can you tell me if it will work or will I have to use a canned tune. The calid from the 2014 is PCM: FSFD1AA. I also have a killer tune for the Steeda CAI. Mike L sent to me me. What do I need to do to make these tunes work. I don't want to load a bad tune to my car, so I will hold off till I hear from you. Thanks, Bud Lum
PCM_FSDL5A8.frg
CALID FOR MY 2011
(1015.99 KiB) Downloaded 393 times
Dynotune.frg
Dynotune
(1015.97 KiB) Downloaded 353 times
budlun
Re: 2011 tune on 2014 stang
Post by budlun »
I can use the T1000 on my 2014 if I use a canned tune can't I. I really would like to use my Steeda CAI and X-pipe. You guys sent Steeda tune to me a for my 2011. Can that be something that is doable for the 2014? Thanx for your time Bud Lum.
dynotune_steeda_212-2.frg
this is the tune. Will it work, or do I need to send you the original and see if you can create one that will
(763.48 KiB) Downloaded 319 times
there should be a version of that same steeda tune in there for the 14 as well :)
budlun
Post by budlun »
mikel wrote:there should be a version of that same steeda tune in there for the 14 as well :)
Hi Mike. Long time. I just updated everything, but I don't see the Steeda CAI on the list. I have tried the universal without much luck. Have I missed something? Thanx, Bud Lum
post your backup here please.
budlun
Post by budlun »
I hope I did this right. I have had such good luck with the 2011 and the tunes you sent me I have about forgotten what little I knew about loading and downloading files. Will the file still be on the T1000, or is it moved to my computer. If I remember right it just copies the file on the tool ,and it's still on the Trinity. I hope this is correct. I also wish I new how to update without loosing my dashes that I took a lot of time doing.Can that be done? sorry to hijack my on thread! Thanks, Bud
PCM_FSFD1AA.frg
(1.03 MiB) Downloaded 337 times
sohfast94
Post by sohfast94 »
Here you go. Old one applied to the new one.
pcm_fsfd1aa_morph.frg
(789.14 KiB) Downloaded 355 times
Insert Clever comment here...
budlun
Post by budlun »
You sofast. Thanks, Bud
Return to “Trinity Ford Gas”
