1r13a + fan settings + MDS
nescafe4all
Post by nescafe4all »
something really weird i discovered after updating my trinity. compared to the previous update
- there is a 43 degrees gap between the tune and the setting, i.e. i set it on 172 F in order to kicks on 215 F
- nothing totally changes once i put the shifter in D or R ( exactly the same factore tune that HS fan kicks on 224 F ) for high speed fan
I do apologize to the people who contribute with my last thread for MDS but sorry guys i was away for couple of weeks and i've just came back
YES THE MDS WON'T SHUT OFF :cry: :cry: :cry: :cry:
P.S. it is 2013 dodge charger R/T with road and track package
this is the last tune written ( i reseted fan settings )
PCM_68171369AC_Modify_Stock_Tune_modified.drg
(1.25 KiB) Downloaded 158 times
Re: 1r13a + fan settings + MDS
MDS is off here.
pcm_68171369ac_MDS.drg
(69.34 KiB) Downloaded 146 times
nescafe4all
thanks Mikel
i installed the tune initally without any modification on the parameters, and MDS still works
until i turn it off and YET IT STOPS WORKING finally :evil_angel: :mrgreen:
and i discovered that the engine revs on 6k RPM in P and N ( which is cool and i love it )
in relation to other parameters i still face the 43 degrees gap in fan settings :( also nothing changes in R and D ( still factory setting on 224 F degrees )
also i set the DRIVE rev limited on 6K RPM but it is actually 5800 !!
here is the last tune written
PCM_68171369AC_pcm_68171369ac_mds.drg_modified.drg
(4.25 KiB) Downloaded 154 times
nescafe4all
Hello !
Im not sure I understand what you are asking sir?
nescafe4all
Fan setting do not work on R and D position in the shifter
Just on P and R !!!!
One i change the shifter the fans turn off immediately
thats something we are looking into.
the changes you apply take effect based on vehicle speed, they dont do anything while its sitting still in reverse or drive.
nescafe4all
I tried to be over 8 MPH many times but it didn't work at all
It looks like nothing's been done ,, fans work at 224 F as stock ,,
please try this tune and let me know if the fans come on sooner.
pcm_68171369ac_mds_fans.drg
(69.34 KiB) Downloaded 157 times
nescafe4all
What figures should i put in fans parameters???
Ans does my car have MS fan ?? Or just 2 speeds: high and low ?
just load the tune, please dont make any changes.
