New Intune DCX
After installing updates i connected my intone to my car and said it may need a calibration update. i press the green check mark and pressed continue. it booted down and i plug back into my laptop. when it opens the software i am greater with a Error thats say the following
An Error has occurred pleas contact [email protected] using calibration id: 68172058AF Status: Error please contact tech support for help.
Application: 1r04d
DCX Tune Db: 1r01q
DCX PID Db: 1r01b
Ford PID Db: 1r01b
GM Pid Db:1r01a
DTC Db: 1ro1a
Vin Db: 1ro1e
Info Db: 1ro1b
All say Ok
Tool status
Version 1r04d
Born 8/15/2014
Serial No:K8XRSBD-7
Tool Type:Diablodcx
Licensed: 0/1
Intune DCX Error *Please Help 2014 Dodge Durango R/T
Re: Intune DCX Error *Please Help 2014 Dodge Durango R/T
please post the info.xml file from the intune drive.
<?xml version="1.0"?>
-<tool_info>
<main svn="7842" sw_rev="1r04d" full_version="InTune-1r04d 08/15/2014 12:04:06 PM"/>
<registration status="1" sn="K8XRSBD-7"/>
<cal_id CM1="68235600AB" PCM="68172058AF"/>
<restore bc="0" vin="1C4SDJCT6EC563004" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01q" mfr="DCX"/>
<db pid="1r01b" mfr="FORD"/>
<db pid="1r01a" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="1C4SDJCT6EC563004" oem="DCX" calid="68172058AF"/>
<updates count="6"/>
<oem tool_oem="DIABLODCX"/>
<reg reg="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"/>
</tool_info>
-<tool_info>
</tool_info>
can you please attach the actual file?
Here
save this to the intune drive and the tool will import it, then you should be able to load it to the truck then load the tunes.wikkid wrote:Here
ok Vasillv sent me a new image file for firmware to use as well. i loaded your file and will test this evening.
working with 2 people is never the best idea, you need the update Vas sent.
Try to stick to one persons assistance at a time, or let the other know, before you get answers from both, that you are working with someone else please.
sorry about that I'm doing what my tuner told me to do which he said email them and get a forum post going too.
ill just work with him on this. thanks for the help
