Page 1 of 2
Intermittent stumble at startup
Posted: Thu Dec 11, 2014 7:57 am
by wcking
I was running 87 octane tune on a 2012 Colorado Sport 5.3 for a few months with no issues but it seems as the weather turned colder the truck has developed an odd intermittent stumble right before it lights off at startup. I have returned the truck back to the factory tune and it seems to have gone away but being that it is intermittent I cant say for sure whether on not it fixed the problem. It almost sounds like a timing issue. This is only at startup. Once it starts it seems to run fine. Has anyone seen this before? Could it be the winter blend of gas here in Cincinnati? I've been running Sunoco 87 octane.
Re: Intermittent stumble at startup
Posted: Thu Dec 11, 2014 8:00 am
by wcking
Forgot to mention that I have a K&N filter and Dynomax single exit cat back.
Posted: Thu Dec 11, 2014 10:12 am
well, there is nothing in the tune that would affect cold start, Id guess its truck related somehow.
Posted: Thu Dec 11, 2014 4:22 pm
by Ill_Born_SS
Remove and clean your MAF sensor and the Throttlebody... it is due.
Posted: Wed Dec 17, 2014 4:29 pm
by wcking
Update:
After running the truck for a week with stock tune I haven't had any issues. I pulled the MAF sensor and cleaned it last night and reinstalled the 87 tune and hard shift tune. After I installed the tunes I realized I hadn't updated the intune since I installed them in the summer (2014). I updated the intune and reinstalled the tunes. Running the truck with the stock tune ECM and TCM was a real eye opener. The 87 tune and hard shift tune really make the truck run like it should. I'm keeping my finger crossed.
Posted: Fri Dec 19, 2014 7:56 am
by wcking
Well the stumble is back. I also notice the hard shift TCM tune is less aggressive than the previous tune that I had installed before the updates. it took about an hour for the updates to finish and mentioned something about updates for GM or Chevrolet. Was there any changes made to the TCM tunes for my truck in the latest updates?
The truck is going back to stock tonight. its a real shame because I like the way the truck runs and responds with the canned tunes installed. I was planning to get a Diablew tune in the spring but its starting to get frustrating now.
Posted: Fri Dec 19, 2014 9:37 am
by Zach
If you would post your tunes up I'll take a look at them.
Posted: Fri Dec 19, 2014 4:46 pm
by wcking
these are the 87 octane and hard shift tunes last intalled.
Posted: Fri Dec 19, 2014 4:52 pm
by Zach
Can you please post the Backups as well?
Posted: Fri Dec 19, 2014 5:18 pm
by wcking
sorry bout that. here they are
Posted: Fri Dec 19, 2014 5:28 pm
by Zach
Hmm.. There aren't any changes in that tune that would remotely mess with start up. Is this something that developed after having the tune install for a while?
Posted: Fri Dec 19, 2014 5:58 pm
by wcking
yes, ive had the tune installed since august of this year. the statrup issue started about a month ago.
Posted: Fri Dec 19, 2014 8:01 pm
by wcking
any ideas on why my latest TCM hard shift tune is less aggresive than previous? I havnt changed any paramters.
Posted: Mon Dec 22, 2014 9:33 am
by Zach
The transmission tune hasn't changed since September of last year, so they're aren't any changes there. IF you would, please load this tune up and let me know if the stumble is still present.
Posted: Mon Dec 22, 2014 3:17 pm
by wcking
Will do, thanks Zach. I assume this is an 87 octane tune?
