writing tune after adjustment using trinity
Posted: Mon Jan 05, 2015 9:17 am
by nescafe4all
what is the best way to write the tune back to the car after adjustment ?
you know 2011+ Dodges are taking a while to install a tune, what I do is saving the tune then upload it using DSdownloader
is that how it works ?
Re: writing tune after adjustment using trinity
Posted: Mon Jan 05, 2015 12:41 pm
using trinity?
just load the tune to the tool then flash it to the vehicle....
Posted: Tue Jan 06, 2015 1:21 am
by nescafe4all
it takes me almost 40 minutes to flash it to the car
also, adjustment of WOT spark and fuel don't work at all, it would be easier if it works
Posted: Tue Jan 06, 2015 11:15 am
loading a tune should take less than 1 minute, its the process of reading the backup that takes 30 minutes or so....
Posted: Wed Jan 07, 2015 2:13 am
by nescafe4all
so how to avoid that 30 minutes each time
Posted: Wed Jan 07, 2015 11:49 am
by 06MonteSS
it won't do it each time.. it only does it the first time you install a tune...
Posted: Thu Jan 15, 2015 3:38 pm
by DavidsChargerR/T
Are you putting the car back to the stock tune and then loading the new tune each time. If you do that then it will take a long time. Once you have backed up the original tune and have no reason to reload it back into the car, you just can replace a Tune or Modify a Tune without ever touching the Original Stock Tune. On my car, it is like Mikel says... If I have the 91 Octane Tune in the car, then modify something in the Tune like turning off the MDS, and then load the new modified tune, it takes about a minute or so to load.
Hope it is something as simple as that which is causing you your problems. If not.. then keep speaking with the Techs.
