Trinity Fan Settings in 91 Octane Modify
Posted: Mon Jan 12, 2015 12:24 pm
I have a 18 degree Thermostat in my 2013 Charger R/T with the 5.7L Hemi AWD. I was in the Modify section of the 91 Octane Tune and chose the Fan Settings. I notice there are about five or so settings. I pretty much set the low fan speed at 182 and the high speed at 185 degrees but when I drive the car on the Highway and it is 30 degrees out, when I stop at a stop light it sounds like the fans are running. I look at the Engine Coolant Gage in the Evic and it says the car is at 178 degrees. The inside Fan is set to off so it is not that which I am hearing. Also, when I turn the car off I can hear the sound of a Fan spinning down.
I will raise the settings to 185 Low and 190 High and see if that takes care of the problem..
Any help with what is happening or recommended settings for a 180 degree Thermostat would be appreciated.
