2004 Hemi Dakota
Posted: Mon Feb 02, 2015 1:45 pm
Background:
- I am running the 2004 Ram 1500 PCM and 5.7 Hemi Engine in my 2004 Dakota.
- Only issues I had on the install that I could not fix were VIN mismatch between the Ram Hemi PCM and my Dakota's ABS module and Stock Stereo System (and AC/Heater controls). To remedy these issues, the dealer had to replace the Ram VIN in the PCM with the Dakota VIN.
The only thing not working is the Cruise Control due to a different number of connections through the clock spring. (will work this later)
I have about 30K miles on the swap (completed March 2012).
I have recently looked at tuning options.
Superchips: T42 error when attempting to pull stock tune from PCM. Have heard speculation from 1)because of the Dakota VIN in the Ram PCM to 2)maybe previous owner tuned the PCM and it is not stock (before the donor Ram was totaled).
I had the dealership momentarily place the Ram VIN back in the PCM and still received same T42 error.
Superchips engineers won't touch it (now I need to sell my Superchips 3865 Flashpaq.)
Diablosport inTune: Based on the success of another person who completed a Dakota/Hemi swap, I am now trying this product.
1) I updated the handheld tuner this weekend. (took about 3 hours)
2) I plugged it into the truck and it told me that for this VIN (the 2004 Dakota VIN), it needed to go online for a PCM update.
3) I took it back in connect to my PC and it stated on the handheld that the update for (Dakota VIN) was successful.
4) I plugged it back into the truck and it read that it was preparing to install an update to the PCM, press continue.
5) It then read that it was ready to install the update to the PCM and if I wanted to go ahead and install. X or (check). I chose NOT to install until I could talk to a rep here.
6) spent the rest of the evening searching and reading similar topics here.
I checked the info file and it referenced my Dakota VIN with the Ram PCM part number (56029166AF) and CM1(transmission controller) part number (56028810AD).
My understanding is that the 2004 Dakota IS NOT supported, but assume the tune is based on PCM Part number, not by VIN. I assume that if the VIN read (alphabet 123) it must stay (alphabet123) while it is married to it.
Question(s)
1) Is the programmer referencing the update because of the PCM Part number (56029166AF) or the Dakota VIN?
2) What are my next steps?
Question(s)
