help need to register
hi i have a 2005 dodge ram 1500 qc 5.7 hemi w/ cai and flowmaster exhaust.
i bought a diablo sport intune ti1000 from a friend today and i need to register it. i have access to a mac and pc. i plugged it into the pc and it updated and i then plugged it into my truck and there was no canned tunes just a few things about shift points and rev limiter. please help i would just like to run some canned tunes till i get familiar with this tuner thanks in advance
info.xml
info.xml
Re: help need to register
please attach the info.xml file.
info.xml
/Volumes/INTUNE/info.xml
please attach the file.
i was having issues with my mac so i switched to a pc just in case that changes anything
save this to the intne drive and the tool will import it and register.ejac014 wrote: i was having issues with my mac so i switched to a pc just in case that changes anything
- registration.itf
- (859 Bytes) Downloaded 970 times
I loaded the file and it went through an update process and then I hooked it up to my truck and it still says I need to calibrate the Pcm.
that means your PCM in your truck needs an update, not the tool...
theberrybear
Having trouble registering just bought?
So I did a reset on my pcm. It still says it needs an update. How would I go about updating it
Have a Mac and need help please
- info.xml
- (1.08 KiB) Downloaded 963 times
Attached my info file. I want to register my intune. My current firmware: Application is 1r04e/Gm is 1r02f. Are these the latest updates available? if not, can you please sent me the updated files for drop? Thanks
- info.xml
- (2.53 KiB) Downloaded 916 times
cmiller0711
Hi,
I have a 2014 wrangler that I have had tuned for almost two years now. I took my jeep into the dealer for an oil change and when I did I took off the tune incase they flashed my pcm. Well they did and now I went to put my tune back on and it says pcm calibration needed. I can not for the life of me remember how to do this could you please help me? Oh and I have a mac at the house which is where I do the updates but I could go to my work and use a pc.
Thank you very much for your time.
here is my info file as well
also my current firmware on the dcx is
app. 1r03s
dcx tune 1r01i
dcx pid 1r01a
ford pid 1r01b
gm pid 1r01a
dtc db 1r01a
vin db 1r01c
info db 1r01b
app. 1r03s
dcx tune 1r01i
dcx pid 1r01a
ford pid 1r01b
gm pid 1r01a
dtc db 1r01a
vin db 1r01c
info db 1r01b
- info.xml
- (2 KiB) Downloaded 934 times
