ABS light after gear swap
zajaco
Post by zajaco »
I have a 2008 GMC Sierra with the 5.3 engine and 33 inch tall tires running the Diablo tune.
I just put 4.10 gears in my truck and started getting the ABS light.
Using my Diablo Predator u1794 running release 9r31, I cleared the code and modified the tune to account for the 4.10 gears. After about 5 minutes of driving with the modified tune the ABS light came back on. I used to see all kinds of posts about the Predator not changing gear ratio. I have that option in my Predator. However, it does not appear to be taking effect. Do I need a custom tune to fix this issue?
Re: ABS light after gear swap
lower the tire size...
2007 and 2008 abs modules have a limit on how big the tire size setting can be..
now since you changed the gear ratio, the setting is probably too big..
so lower the tire size by a half inch, and see if that solves it..
if not, lower it by another half inch, etc etc..
zajaco
Post by zajaco »
That appears to have worked. No ABS light on the drive to work this morning. FYI, for anyone running this setup (33 inch tall tires and 4.10 gears) I set the tuner to a 4.10 gear ratio and 25 inch tall tires. I verified with GPS on the way to work and my spedo is about 1 MPH fast at 40 MPH. IE, my spedo shows 41 and my GPS is showing 40. Close enough for me.
cool deal..
yeah, within 1-3 mph is acceptable...
hell, I checked my wife's totally factory stock CTS once with my phone gps, and her speedo was showing about 2-2.5 mph off compared to gps, heh...
06MonteSS wrote:cool deal..
....again, I say user error :)
rofl...
rofl...
LOL.. douchenozzle!
