06 ram 1500 spt 5.7 crew 89 octane 4x2 pred u7137
lilphiliraq
I called the number on the support page and it told me to check the forums on a weekday. I know it's the weekend. My vehicle is a 06 Dodge ram 1500 5.7 with 24 inch rims and tires. I now own a predator u7137. the person showed me how it works a little bit. I watched the video on this site. My few questions are: Will the predator work with a Jet performance module stage 1 which plugs in the ECU? Before I experiment with the predator, can I really raise the speed limiter and if so how much? I'm trying to connect to computer, but windows 7 can't installed software to connect the predator. Any little details and extra info will gladly be used. Thank you and thanks to diablo sports and staff for creating a great product. I've seen mostly good reviews online and purchase this from a stranger for $200 which couldn't use on the 09 or 2010 challenger. 504-570-7012
Re: 06 ram 1500 spt 5.7 crew 89 octane 4x2 pred u7137
Id ditch the jet thing, ts not doing anything for you.
The tuner will let you raise the speed limiter well past what the truck will do without a really long hill
Sounds like you need to install the driver for the USB to serial cable to get it to connect to the PC, try this one:
www.diablosport.com/drivers
lilphiliraq
finally got the predator up and running. most gas stations have 87, 89, 91 octane my manual/manufacturer book says 89 recommended. the predator doesn't have that option. do I pick 91 and start purchasing 91 octane or is 91 understood as 89? about my jet module lol. I'm a lil hurt about taking the jet off. Does it hurt, help, break even, or possibility of damage/malfunction? it does does give 10hp according to its website dyno chart. thanks Mr. Mike
the best power will come from the highest octane tune and fuel you run.
From what I have seen that other device is doing nothing at all.
lilphiliraq
the predator has options of 89, 91, and 93. I never heard of 93. Never saw it at a gas station. That's why I ask is the octanes on the predator is understood as 87, 89, and 91?
I live in Texas and every gas station has 93 octane at every pump lollilphiliraq wrote:the predator has options of 89, 91, and 93. I never heard of 93. Never saw it at a gas station. That's why I ask is the octanes on the predator is understood as 87, 89, and 91?
