LS2 running lean
Posted: Mon Mar 09, 2015 4:03 am
I drive a 2005 Corvette C6 with the LS2 engine. Over here in the Netherlands all cars have to be tested for emissions every year, and so far this was never a problem.
Without changing anything to the engine this year it seems the car is running way to lean, therefore the lamba is to high, and the car will not pass the test.
Please help me in finding out where to look for the problem, and how the Trinity can help me in finding the cause of the engine running lean.
I'm not a mechanic but to me it seems that the engine might have a leak where it is sucking in extra air which is not being recorded by the MAF.
Please feel free to make suggestions on where to look for the problem.
Below are the figures from the test, they measure at idle and 2500 rpm.
Engine idling:
CO (max 0.3%) 0.46%
HC PPM Vol 120
Lambda 1.102
Engine 2500 rpm:
CO (max 0.2%) 0.53%
HC PPM Vol 48
Lambda (max 1.03) 1.040
Greetings
Fred
Engine idling:
CO (max 0.3%) 0.46%
HC PPM Vol 120
Lambda 1.102
Engine 2500 rpm:
CO (max 0.2%) 0.53%
HC PPM Vol 48
Greetings
Fred
