missing knock gauges
Posted: Wed Mar 11, 2015 12:30 am
by brandon23
i just bougt a trinity, so im new on this, i was triying to see if i have knock but i cant find the knock gauges
just this ones:
COOLING: AMB TEMP(F)
AMB TEMP
AMB TEMP AVE (F)
TEMP V (VOLTS)
EXH TEMP (F)
IN MAN AIR TEMP (F)
IN MAN GAS TEMP(F)
OIL TEMP
CYLINDER: TCYL VE MOD (MULT)
ELECTRICAL: BATT V (VOLTS)
BATT V FILT (VOLTS)
BATT V SCALED (VOLTS)
O2S II DEF GOAL V
TPS 1 V (VOLTS)
TPS2 MIN V (VOLTS)
TPS 2V (VOLTS)
TPS CALC V (VOLTS)
EMISSIONS: EGR EXH TEMP(F)
EGR FLOW (G/S)
EGR MASS FLOW (G/S)
EGR PRATIO (P RATIO)
EGR SONIC FLOW
EXH PRESS (KPA)
IN MAN EGR MASS
THROTTLE: ACC PDL POS %
BASE IDLE SPD (RPM)
THR ANGLE (DEG)
THR BLADE (%)
THR POS (%)
THR POS V (VOLTS)
TRANSMISSION: TRANS OIL TEMP (F)
