T100 Help Improving Throttle Response
mpaladino
Post by mpaladino »
Hey guys.
This might have already been covered in previous discussions, but I can't seem to find the answer...
I've got a 2014 Challenger R/T Plus 5 speed auto with the 91 Tune, MDS disabled. I've noticed that the throttle response lately is not that great. When I first ran the tune, the head snap was much better. The most noticeable lag is when I'm going street speed, around 35mph. When I hit the accelerator hard, the engine revs really high but the car doesn't really take off like it used to. Is there anything I can do to my tune to improve this?
I see parameters like WOT Spark/Fuel, Rev Limit, etc... but since this is the first tuner I've ever owned, I'm a little hesitant to start messing with these settings. Don't want to mess things up.
Can anyone provide some advice or recommendations?
Also, what's the difference between the 91 and 93 tunes? Do you have to run 93 oct gas on the 93 tune? NOOB is learning.
Re: T100 Help Improving Throttle Response
have you tried adding some throttle boost?
mpaladino
Post by mpaladino »
mikel wrote:have you tried adding some throttle boost?
Not yet. Got any recommendations for what that should be?
mpaladino
UPDATE Re: T100 Help Improving Throttle Response
Post by mpaladino »
So I adjusted the throttle boost, adding 10%. Boy, what a difference. That seems to do the trick. Hope this helps anyone else experiencing the same issue.
that's a fun parameter :)
You can play with it to find your optimal setting.
