I1000 Crashes on TCM Tune
speedbee29
Post by speedbee29 »
I have a 2005 Dodge Ram 1500 5.7 Hemi 2wd. I updated my I1000 a week ago, and when I went to re-tune my vehicle, the tuner will crash and restart as soon as it starts to tune the TCM with performance tune. It says the PCM completed, but after it restarts, it starts up in 'Recovery Mode', and will not let me do anything else really. If I say continue, it says its going to restore original stock tune, and then crashes again and starts over and loops the whole process again. I looked at the Info.xml file and my trucks VIN is listed in that file, but if I try to do DTC scan, it says only registered vehicle is allowed, and its the same vehicle that I just tuned (but crashed). Ive had the registry reset with tech support, but as soon as my tuner tried to tune the TCM its crashed and is not stuck where its at. Basically a paper-weight now. What can I do, does anyone have any suggestions? Anyone have this problem as well?
Tuner software ver. 1r04e
-<license tuned="1" avail="1">
<tuned vin="1D7H******
Re: I1000 Crashes on TCM Tune
please post the info.xml file from the intune drive here.
speedbee29
I have attached the info.xml file
DiabloSport I1000 Info file.txt
(1.97 KiB) Downloaded 304 times
copen550cat
Post by copen550cat »
I have a 2014 Chevy Silverado 1500 5.3 and it did the same thing. I udated my t1000 like i do every other month or so. I did a modified stock tune and it said error then loaded the restored the original tune. Now my truck will not start or recognize the t1000. It says to turn the key on but do not start the vehicle. Im lost but all I know is that it would be nice to have an emergency tech support over the weekend. Hopefully I can get some help tomorrow.
hebe_jebe
Post by hebe_jebe »
fingers crossed for you. mine did the same thing. they were able to fix it over the phone. i would suggest calling as soon as they open. have your tuner and computer close by your vehicle. I use a laptop and it made things a little easier. By the end of the day they had made a file or something to fix everything. They'll walk you through a series of steps to correct whatever failed with the tuner.
speedbee29
Hey Mike, did u take a look at my info.xml file to see if there is a problem with my tuner? havent heard anything from you in a while.
any files in the runtime folder on the intune drive?
speedbee29
Hey Mike,
There are 3 files in the Runtime folder:
runtime_00.dbg
runtime_00.dbg
(483.93 KiB) Downloaded 234 times
runtime_01.dbg
runtime_01.dbg
(409.08 KiB) Downloaded 255 times
runtime_02.dbg
runtime_02.dbg
(437.45 KiB) Downloaded 261 times
speedbee29
mikel wrote:any files in the runtime folder on the intune drive?
I left downloads of whats in my Tuner's runtime folder.
hemipower3315
Post by hemipower3315 »
Same issue. I have 03 ram hemi and converted to 2005 wire harness and computer for better tuning. Intune did exact same as you. Only option was to take to dealership to reset to factory tune and then unlock intune after that. Unfortunately I dont have dealer close so having to sending pcm and tuner into diablo to reset themselves.
speedbee29
hemipower3315 wrote:Same issue. I have 03 ram hemi and converted to 2005 wire harness and computer for better tuning. Intune did exact same as you. Only option was to take to dealership to reset to factory tune and then unlock intune after that. Unfortunately I dont have dealer close so having to sending pcm and tuner into diablo to reset themselves.
Crap, I hope I dont have to go thru all that. This Tuner just seems to have some corrupted files. Worked fine when I first loaded up 87 octane tune, then it went to hell after I did an update.
speedbee29
Hey Mike,
Were u able to see if there is anything wrong with whats in my Runtime files? Havent heard from you in a while about this again.
Thanks for your time
speedbee29
Still having the problem with my I1000, can any of the tech guys take a look at my uploaded files? WOuld like some answers, its frustrating having a $400 paper weight. Product worked good, when it was working.
:blowup:
We're looking through the files.
speedbee29
Ok thanks, let me know if you need me send anything else. Hope you can figure out whats wrong with my tuner.
Have a good one.
:normal:
