85mm MAF on F-Body
M.RedWS6
85mm MAF on F-Body
Post by M.RedWS6 »
Is it possible for you to provide me with a tune that recalibrates the computer with the new calibration table corresponding to an 85 mm MAF?? If so what do you need.
I am having a problem with the LTFT running very lean even after LT header installation and I believe that it has to do with the MAF. I had a friend lend me his MAF from his camaro and monitored the LTFT and there was considerable improvement (from +11 LTFT on both banks to +3.91 LTFT after swap)because of it. I don't want to have to buy a new MAF sensor if the calibration table of the 85 mm MAF can be programmed into a custom tune?? What are my options??
RE: 85mm MAF on F-Body
Honestly, the longtubes alone would warrant a custom tune done on a dyno, and doing that will allow the tuner to perfectly dial in the MAF curve.
Check our dealer locator for a dealer near you that can tune it for you.
