Problem ,Cadillac cts 2014 2.0
Hi there, after Intune installation (91 oct) my car started to make crazy noise on 6000+ APM(noise comes from transmission or engine) , Speedometer acting slow . What is the problem? What should i do?
The first thing i did , i resetet all installed parameters and now waiting for some kind of help. I Was calling to diablo sport 3 days in a row, and no answer (All operators are busy).
Re: Problem ,Cadillac cts 2014 2.0
please post the files from the tunes folder on the intune drive here.
what klnd of noise are you hearing?
Kind of metal noise. Like to metal pieces hitting each other. I just checked tune file, and its empty, maybe because i returned to stock? Is it anyway you can make tune and ill load in my car?
yeah, you have to have the preset tunes installed so that the tool saves copies of the files in itself in the Tunes folder...
I am going to do it right now. What kind of transmission shit should i do? Hard or?
Last tune
- ECM_12659715_LastTuneWritten.grg
- (123.55 KiB) Downloaded 204 times
Second last tune file
- TCM_24271052_LastTuneWritten.grg
- Second ' Last tune file'
- (50.3 KiB) Downloaded 258 times
You need to post up the original backup stock tune files too.
ready
- TCM_24271052_Backup.grg
- (49.99 KiB) Downloaded 289 times
- ECM_12659715_Backup.grg
- (122.46 KiB) Downloaded 262 times
does the vehicle run good with the stock tune loaded?
can you record a datalog so we can see it?
Yes, it does run good. Where or how can i get datalog?
the tool will record it by clicking scan tool/datalogging/record, then save it to the intune drive/logs folder.
Here it is
- 1G6AR5SX9E0181191_00.log
- (86.2 KiB) Downloaded 354 times
and here is datalog on stock tune
- 1G6AR5SX9E0181191_01.log
- (78.53 KiB) Downloaded 348 times
were you driving whenyou recorded these logs?
