Do I need any to change any other parameters
Posted: Wed Apr 01, 2015 12:37 am
by sumry
Hi,
I am have with my InTune DCX unit. I am running Octane 91 tune on my 2014 Sahara Wrangler Automatic transmission. I have modified the tyre size (35") and Gears (4:10) to match what I got.
Is there any other parameters that I need to change. What about gear shift points? How can I modify that?
Thanks for your help.
Re: Do I need any to change any other parameters
Posted: Wed Apr 01, 2015 9:53 am
Shift points are not currently adjustable, you shouldn't need more changes.
Posted: Thu Jun 11, 2015 12:08 pm
by firefighters_axe
mikel wrote:Shift points are not currently adjustable, you shouldn't need more changes.
Mikel, Can you clarify this a little more? He needs shift points changed due to re-gearing but unfortunately they are not part of the parameters? Aside from that, he shouldn't need more changes? So, basically anyone who re-gears will not be able to compensate for the change?
I'll keep using the search button.
Thanks.
Posted: Fri Jun 12, 2015 8:57 am
the device allows you to program for the new gears to calibrate the speedo, which corrects the shift pattern, no other changes should be required.
