LX rear gearing
Someguys300c
LX rear gearing
Post by Someguys300c »
sorry if its been asked. i did a search and came up with nothing.
as it stands, no company will make rear gears for the LX. Because they are unusable, the computer will go to limp mode.
so will the predator be updated in the near future, to allow us to adjust for different gearing?? maybe then we can get quaiffe on board with making us a gear set. there is huge demand for it at this point.
i assume that since it wasnt released with the first release. that there must have been a roadblock for you guys, on this issue. obviously with the lack of available gearing, it makes it hard for diablo to hack the tuning for gears by trying out a different set.
but is there some reason you cant use different wheel/tire sizes to simulate a different set of gears. just to get the calculations figured out for gearing??
RE: LX rear gearing
Yes, we will be adding support for gear ratio adjustment.
Taller tires will not work, as it measures it in the differential.
Someguys300c
RE: LX rear gearing
thanks. dont suppose there is any ETA on the gear ratio adjustment?? or am i pushing my luck now?? lol
