U7185 Duramax LLY glitch
Posted: Sat Mar 10, 2007 4:52 pm
by RobertJacob
I loaded the 65RWHP (std tune) into my 2005 Chevy. I got great performance and fuel economy right away. After driving it for about 500 miles or so I got on it and suddenly the engine wouldn't rev past 2000 RPM in any gear. I pulled off the road, shut the engine off, checked my air intake (which was fine). After I started it up again, it was fine. This has happened twice since then. Any ideas?
RE: U7185 Duramax LLY glitch
Posted: Mon Mar 12, 2007 12:11 pm
Are you running any other aftermarket tuning devices in the truck?
Posted: Mon Mar 12, 2007 9:23 pm
by RobertJacob
I am using the K&N cold air intake kit but no tuner other than the pedator.
Posted: Tue Mar 13, 2007 8:38 am
by lccmo
RobertJacob, Have you changed your fuel filter lately? What code did you get a 1093? If so and you have changed your fuel filter go to one of the larger duramax forums and search of 1093.
Posted: Tue Mar 13, 2007 9:04 am
by johan
Lccmo has a good point, i change my filter every other oil change. It could also be a P0101 air flow issue which i have seen with some aftermarket air intakes but that only seems to happen on Cali. emissions equipped trucks.
Posted: Fri Mar 16, 2007 9:34 pm
by RobertJacob
Ok, after reading the replies and my original message, I thought I should give more data. This problem acts as if the rev limit has been changed to 2000 rpm. The engine revs and cuts and revs and cuts if I try to push past 2k rpm. I have driven another 500 miles on the 85 hp tune and it is just fine.
Posted: Sat Mar 17, 2007 8:38 am
by lccmo
RobertJacob
have you checked the codes? Does it do it stock? Have you changed your fuel filter? The 2000 rpm limit sounds like a 1093 code, the usual causes of a 1093 are
1) clogged fuel filter
2) the rail relief valve spring is weak.
3) running a BIG tune - (65-85 isn't big
Usual fixes for a 1093:
1) change the fuel filter
2) add a lift pump
3) shim the relief valve.
Goto
www.dieselplace.com and do a search for 1093.
Posted: Sun Apr 08, 2007 3:02 am
by Tigermax
[quote="lccmo"]RobertJacob
3) running a BIG tune - (65-85 isnFuel rail pressure relief valve and EGR plate. Just got mine replaced under warranty
Posted: Wed Sep 19, 2007 4:14 pm
by rokbrnc
I just had this happen as well. I have been running the Diablo tuner set at "65" with an S&B air intake for about a month now. I changed the fuel filter at the same time and it has been running great ever since.
However today when I got on the freeway, it revved to 2000rpm and then surged and would not go back above 2000rpm. I checked the code, and yes it is a P1093 which I looked up the info on from thedieselpage.com forum which says this can also be attributed to sudden changes in atmospheric temperatures. I am in NorCal and yesterday we had a high of 88 degrees, today it's only going to be 58 degrees.
For now I have reinstalled the factory tune, and reset the code. Is this something that I should be concerned about though in the future? Is it a fluke, or possibly related to the use of the tuner?
Posted: Wed Dec 24, 2008 12:44 pm
by Kellen
I have this problem a number of times. Does it happen when you floor it and then back off suddenly? If so, your truck has a minor momentary loss in fuel pressure and when it catches back up the influx in different pressure trips the code. It is a pain in the ass but that tiny glitch will throw the code. Also after you floor it lay off the throttle easily and that should help.
