P0520 code only with tune installed
rlesch
Post by rlesch »
Hi, I have recenlty been having issues where the P0520 (oil pressure sensor malfunction) code is thrown when I have the 91 and 93 octane tune installed. When I return back to stock the code goes away. Should I just clear this code with the tuner when it shows up with either canned tune installed?
Re: P0520 code only with tune installed
can you load the tune then post the tunes from the tunes folder on the intune drive here please?
GilaRider
Post by GilaRider »
If your vehicle is still under warranty, the dealer will fix this problem for you at no charge. The tuner is simply showing you the malfunction, and I found out about it on my car even though I had the wrong tuner. :mrgreen: Just be sure your tune is stock when you take it in for service.
