3.73 Gears with custom tune
Posted: Wed Apr 15, 2015 9:03 am
by Virge
Hi, i've just installed on my mustang a 3.73 gears..
I have a custom tune, if I change the axle ratio with the predator it will be adjust the speedometer only or also adjust the shift points?
Re: 3.73 Gears with custom tune
Posted: Wed Apr 15, 2015 12:09 pm
it will bring it all in line
Posted: Thu Apr 23, 2015 3:45 pm
by Virge
Thanks!
I set "3.73" in the axle ratio and set 746 on tire revs for mile (i have a 255/35 20), but i noticed that the speedometer is about 6/7 MPH faster than the GPS signal... Why?
Posted: Thu Apr 23, 2015 6:12 pm
did you select the enable axle ratio change parameter as well?
Posted: Fri Apr 24, 2015 3:06 am
by Virge
Yes, i set the axle ratio and tire revs for mile and i install the tune, but speedometer is wrong.... if I send to you my tune can you correct it for the new gears? Thanks!
Posted: Mon Apr 27, 2015 6:59 am
by Virge
I tried to install a 95 mm tune (i have a ford racing cai), and i set the 3.73 axle ratio but my speedometer continues to be wrong. I try to install my original backup and I set the 3.73 axle ratio but the problem has not been resolved...
What can i do?
Posted: Tue Apr 28, 2015 11:28 am
export the files and post them here please.
Posted: Tue Apr 28, 2015 3:54 pm
by Virge
Thanks, I attached the file
Posted: Tue Apr 28, 2015 5:32 pm
by sohfast94
Here you go. All fixed. There were some old errors here that will be fixed this week and out on the next update.
