Open loop AFR stick to to 14.53
AlexIV
Post by AlexIV »
Hi, folks
I made 91 tune. JGC 2012, Hemi. Than I wrote two logs.
I wonder that desired AFR had been changing (as it should be) and open loop A had not.
Just straight line of open loop AFR value and min -max-actual figure glue at 14.53
If oxygen sensor is out of function it will not be such average value. No fault codes wrotten in PCM .
Does it mean presence of software bugs in tune or smth. else ?
Regards,
Alex
Re: Open loop AFR stick to to 14.53
The PCM cant actually monitor AFR in open loop, so theres not much to see there ;)
AlexIV
Post by AlexIV »
Thanks, but in previous logs I'd saw moving open loop AFR. More or less in accordance with desired AFR.
AlexIV
Post by AlexIV »
mikel wrote:The PCM cant actually monitor AFR in open loop, so theres not much to see there ;)
One more log have been reviewed. So at WOT only straight line of AFR at 14.53 drops to 11.35 for few seconds. Means PCM can monitor the open loop AFR ?
no, you are seeing commanded AFR there, not actual.
