2006 Pontiac Grand Prix GXP diablo tune issues
General Trinity Support
GXP_Wally
Post by GXP_Wally »
I just purchased an diablo trinity for my 2006 Pontiac grand prix gxp, and when I install any of the tunes I get an looping idle, currently using just the modified stock tune. Only mods to the car are an CAI air intake and a SLP 160 thermostat, NGK laser plugs and bosch wires. Need help please
Re: 2006 Pontiac Grand Prix GXP diablo tune issues
yep, I know exactly what the problem is..
Did you update the trinity first to the lastest updates before installing the tune??? I thought that issue was fixed a long while back...
the issue can be fixed in a custom tune.. post up your ecm original backup and last tune written files...
GXP_Wally
Post by GXP_Wally »
Ok I will as soon as I get home from work. Which is like 7pm est time
GXP_Wally
Post by GXP_Wally »
Here is my original backup and last written tune
TCM_235742236494_Trans_Firm_Shift_Tune_modified.grg
(2.25 KiB) Downloaded 507 times
PCM_602095602425_Modify_Stock_Tune_modified.grg
(3.25 KiB) Downloaded 327 times
TCM_235742236494.grg
(13.63 KiB) Downloaded 354 times
PCM_602095602425.grg
(42.92 KiB) Downloaded 291 times
so you're only running the stock tune? you should not have the jumping idle if you are only running the stock tune.. that issue only happens with the diablosport tunes...
so which tune do you want the fix for???
you'd need to select/install the tune you want to use - 91 octane No DOD or Diablo Tune No DOD...
then you need to post up the last tune written file after that, so the fix can be applied to an actual tune...
GXP_Wally
Post by GXP_Wally »
Yeah, its just when I installed the diablo tunes, I will install one then upload it
GXP_Wally
Post by GXP_Wally »
Here are my last written diablo tune
(2.25 KiB) Downloaded 327 times
PCM_602095602425_Diablo_Tune_no_DoD_modified.grg
(5.25 KiB) Downloaded 349 times
hmm.. can't even open your tune files.. no tune template for your calibration...
Mike/Zach, any ideas? need a new template for this???
GXP_Wally
Post by GXP_Wally »
If i do an data log from stock could you make me an tune, and if i drive the car with that looping idle will it harm the car
GXP_Wally
Post by GXP_Wally »
Someone had told me that I probably have to relearn the throttle body, is that true?
can't make anything for you at this point, there's no template for your particular calibration.. so can't open your tune files... engineering has to create one, and from what I hear, it won't be any time soon... that's an ollld calibration, so it's not at the top of the list of things to do...
GXP_Wally
Post by GXP_Wally »
What if i go to the dealer and get my computer updated?
yes most likely..
make sure you restore the original backup stock tune to the car first before going for dealer flash update..
GXP_Wally
Post by GXP_Wally »
I finally took it to the dealer for an update, but it still surges when accelerating, can you fix it for me please og
(2.25 KiB) Downloaded 382 times
PCM_604792604820_Diablo_Tune_modified.grg
Diablo Tune
(4.25 KiB) Downloaded 310 times
Tcm
(13.63 KiB) Downloaded 245 times
PCM_604792604820.grg
updated original pcm
(42.91 KiB) Downloaded 299 times
GXP_Wally
Post by GXP_Wally »
06MonteSS would you be able to help now?
Return to “General Trinity”
