Back to stock and now I have check engine codes
Posted: Wed May 06, 2015 10:45 pm
by slimharpo
Ok so I just went and did the back to stock on my car. After the download my car threw a bunch of check engine codes is this normal. I reset them but I'm a little worry. And next question if you disconnect your battery does the car loose the tune from The Trinity.
Re: Back to stock and now I have check engine codes
Posted: Thu May 07, 2015 8:49 am
by 06MonteSS
disconnecting the battery does not delete/erase the tune/programming.. think of how many dead vehicles there would be on the road if that happened every time someone had to replace a battery.. ;-) tunes/programming does not get erased from the pcm...
Posted: Thu May 07, 2015 9:50 am
by slimharpo
Okay so is it normal that my car throws that many codes by putting it back to stock
Posted: Thu May 07, 2015 10:12 am
by 06MonteSS
nope.. shouldn't be throwing any codes.. unless you have mods done that cause it, like headers, high-flow cats, or no cats, etc.. then yes, you will throw codes with stock tune...
but if you car is all stock, then no, you shouldn't be throwing any codes... unless there's an actual problem with the car somewhere...
