Page 1 of 2
Throttle Body Closing during shift
Posted: Thu May 14, 2015 6:18 am
by MyChallyNow
I am just wondering why this takes place during the shift at gear change, I know that did not take place on our 07 Daytona using the predator. Out the exhaust it sound like a Big ol Fart during the shift.
:normal: ?
Re: Throttle Body Closing during shift
Posted: Thu May 14, 2015 10:42 am
what vehicle are you asking about specifically?
Posted: Thu May 14, 2015 3:26 pm
by MyChallyNow
2013 Challenger R/T 5.7 A5
Also when updating with Diablosport Intune DCX puts a back date on the pcm....On this car AE .. Back dating to AC. When I had the brakes checked today, they hooked up and said miles were 94,498..............while the dash says 58xx miles.
Now again today they updated the PCM . 2 times updated and I cannot load Intune again...........with out going back to pc and "Update" the intune.
This is getting interesting.
Tom
Posted: Thu May 14, 2015 4:04 pm
post the info.xml file from the intune drive please.
Posted: Thu May 14, 2015 5:33 pm
by MyChallyNow
calibration id to AE today
Posted: Thu May 14, 2015 5:40 pm
save this to the intune drive then you can load the cal update to the car then load the tunes.
Posted: Thu May 14, 2015 7:08 pm
by MyChallyNow
OK will do in the morning. What does ID change?
Thanks Mike.
On a log the throttle position percent does max out at 127.1. That i am use to. Now the throttle blade percent max out at 76.29. Should that actually be maxed out at 100?
It sure sounds as if the throttle body is closing at the shift point.
Posted: Fri May 15, 2015 1:17 pm
by MyChallyNow
Mike here is my last written
Posted.
Again why is there so much torque management left in the canned tunes. The predator had less where you feel mds on and off, All I can see is the "ECO" symbol comeing off and on.
Tom
Posted: Fri May 15, 2015 1:46 pm
by sohfast94
Try this and see what you think.
Posted: Sat May 16, 2015 1:34 am
by MyChallyNow
Ok sohfast94 what have you done to this? Is this a 91 or 93 tune? Clue me in...at least.. today alot of rain.
First thing in the morning.
Thanks Tom
Posted: Sat May 16, 2015 2:34 am
by MyChallyNow
will run in the morning
Posted: Sat May 16, 2015 9:15 am
by MyChallyNow
Not bad for a stock car. Small hesitation at the shift but better.
Posted: Mon May 18, 2015 11:30 am
glad to hear it, enjoy :)
Posted: Mon May 18, 2015 11:40 am
by sohfast94
MyChallyNow wrote:Ok sohfast94 what have you done to this? Is this a 91 or 93 tune? Clue me in...at least.. today alot of rain.
Thanks Tom
Had just finished making this tune for the new 5.7Ls on the dyno and street
Did it with 93octane. Not aggressive enough to worry about though. If you have 91 I can adjust it for you. Didn't even cross my mind at the time.
Anyway. The difference between the old hemis and the new 8 speeds is a lot more is hidden in the TCM with the shifting also they have them turned up quite a bit more than in the past on the engine side.
Posted: Mon May 18, 2015 9:30 pm
by MyChallyNow
It grabs second gear real good in auto. Paddle shifting, I cant put my finger on it as to what it is in the shift. When it hits second its good. But some sort of "free spinning" during the shift the into second aggressive.
I guess if I feed it BP it should wake up more.
Plum Krazy says Hi to Johan
