PCM Calibration Error/Vehicle Not supported
Posted: Mon May 18, 2015 7:15 pm
by jkrehlik
Just got my new I1000 Intune a few days ago. Did my online update. Everything seemed to go just fine. First try at "Writing a Tune." I get the error message stating "This Vehicle Not Supported" and then "The PCM Calibration might need an update." I exit, re-update online and it says I am up to date, What am I missing here?
2008 Chrysler 300C w/ 5.7 Hemi.
Thanks in advance!
Re: PCM Calibration Error/Vehicle Not supported
Posted: Tue May 19, 2015 9:46 am
click the check mark and follow the prompts to plug it into a pc and let it check for an update for the vehicle :)
Posted: Tue May 19, 2015 10:03 am
by jkrehlik
That has been done. I still get the same exact error. The software says no update available.
Posted: Tue May 19, 2015 11:03 am
force it to check for updates by going to the top menu, select UPDATES and click on CHECK NOW...
Posted: Tue May 19, 2015 11:13 am
post the info.xml file please.
Posted: Wed May 20, 2015 2:11 pm
by jkrehlik
mikel wrote:post the info.xml file please.
Here you go Mike, thank you.
Posted: Wed May 20, 2015 3:25 pm
save this to the intune drive and let the tool import it then go load it to the car, then you may tune it.
Posted: Wed May 20, 2015 9:58 pm
by jkrehlik
That did the trick! Tune went fine. Thank you!
Posted: Sun May 31, 2015 12:33 am
by dut192
Can you do this for me? I tried tuning my 2005 corvette and when I do I get the same "PCM calibration for vin might need an update" and the same for TCM. Please let me know asap. Heres my info file. I also emailed tech support. Thanks!
Posted: Sun May 31, 2015 8:47 am
by davetrem
same thing it is saying vehicule not supported calibration id: 0509407AG satus error. I have 06 durango 4.7 liter engine
Posted: Mon Jun 01, 2015 9:41 am
4.7 Durango support is 07+ unfortunately.
Posted: Mon Jun 01, 2015 12:37 pm
by davetrem
mikel wrote:4.7 Durango support is 07+ unfortunately.
did the Trinity support it ? Durango 4.7 06 ?
Posted: Tue Apr 12, 2016 7:23 pm
by Ronalda27
hello,
I just received my intune i2. I did the updates and then went to try to tune my 2007 Chrysler 300C 5.7L HEMI but I got the same error message that my vehicle is not supported. Can someone please help? I attached my info doc.
Thank you
Posted: Mon May 02, 2016 10:00 pm
by ssixthsense66
Ya know I had this error at first ' I had the key in acc. instead of ON. then it worked. but I plugged it into the port 1st before turning the key.
