Page 1 of 5
2015 F150 EcoBoost tunes now available from Diablosport
Posted: Wed Jun 10, 2015 4:07 pm
We have released tunes for the 2015 2.7 and 3.5 Ecoboost models on our T-1000 Trinity and I-1000 inTune models.
Tunes for 87, 91 and 93 octane are available for both applications.
PRELOADED TUNES:
93 PERFORMANCE TUNE:
2.7L +40 HP | + 70 TQ
3.5L +70 HP | +100 TQ
91 PERFORMANCE TUNE:
3.5L +65 HP | +90 TQ
87 PERFORMANCE TUNE:
2.7L +30 HP | + 60 TQ
3.5L +50 HP | +70 TQ
TOWING TUNE:
MILEAGE TUNE:
TOWING TUNE:
Available end user parameters:
Disable Auto Start/Stop (2.7L Only)
Global Timing Adjustment
Gear/Tire Size
Idle RPM
WOT Fuel Rich/Lean Adjustment
Cooling Fan Control
Intake/Exhaust Cam Adjustment vs. RPM
WOT Spark Timing Advance/retard
Raise Speed/Rev Limiters
Shift Points/Shift Firmness
Tunes are released and available now on any T-1000 Trinity or I-1000 inTune.
Let me know if you have any questions!
Re: 2015 F150 EcoBoost tunes now available from Diablosport
Posted: Thu Jun 11, 2015 3:49 pm
by mobb70
Is this the same tune used on the 13 and 14,s as well? I noticed the TQ went up on some since I last downloaded to my Trinity. Thank you.
Posted: Thu Jun 11, 2015 4:14 pm
No, the 15 F150 3.5 is a new animal, it makes a bit more power stock and uses an entirely new calibration.These are newly developed tunes specific to the 2015 models.
Posted: Thu Jun 11, 2015 8:02 pm
by kellyfj10
I downloaded the update, when I go to install it says 2014 and doesn't give me all the tunes you have listed above. Is that right? It downloaded in my truck ok.
Posted: Thu Jun 11, 2015 9:35 pm
by mobb70
Thank you sir for the quick reply.
Posted: Fri Jun 12, 2015 9:04 am
kellyfj10 wrote:I downloaded the update, when I go to install it says 2014 and doesn't give me all the tunes you have listed above. Is that right? It downloaded in my truck ok.
it should let you pick 2015 now after the update was loaded, but if you are loading tunes, you are good to go
Posted: Fri Jun 12, 2015 4:23 pm
by kellyfj10
It let's me pick my 2015 F150 3.5 ecoboost but then b it says the tune is only to 2014. Then after I loaded it to my truck it had no throttle. It was the 87 octane tune. I restored the original and it drove fine. I tried to download the tune from site and load it in the truck again and it did the same thing. Any suggestions?
Posted: Fri Jun 12, 2015 4:33 pm
kellyfj10 wrote:It let's me pick my 2015 F150 3.5 ecoboost but then b it says the tune is only to 2014. Then after I loaded it to my truck it had no throttle. It was the 87 octane tune. I restored the original and it drove fine. I tried to download the tune from site and load it in the truck again and it did the same thing. Any suggestions?
options/show information, what is the version?
Posted: Fri Jun 12, 2015 4:39 pm
try a different tune if you get a chance please.
Posted: Fri Jun 12, 2015 10:36 pm
by kellyfj10
The version is v.1r13f. I loaded the premium tune and had the same result, no throttle response after a couple of minutes. Then when I tried to load the original tune back it said that the tuner was used to load a 2004-2014 f150 and it wouldn't let me go any further. After several attempts it let me load the factory tune back.
Posted: Sat Jun 13, 2015 12:02 am
by Roiceed
kellyfj10 wrote:The version is v.1r13f. I loaded the premium tune and had the same result, no throttle response after a couple of minutes. Then when I tried to load the original tune back it said that the tuner was used to load a 2004-2014 f150 and it wouldn't let me go any further. After several attempts it let me load the factory tune back.
I had the same issue for the last couple weeks. I never had any issue restoring it back to factory though. Good to know its not only me. Are you using a XLT 3.5 ecoboost aswell?
Posted: Sat Jun 13, 2015 8:16 am
by kellyfj10
Yes, I have 3.5 ecoboost XLT 4x4.
Posted: Sat Jun 13, 2015 11:46 pm
by heath t
Mine has a bad hesitation at part throttle. Its spitting and sputtering. Between 1/4-1/2 throttle, the truck lurches and sputters. No backfiring, just acts like it loses all throtle or fuel fo ra spilit second. It does it constantly and consistantly at part throttle. Im also currently running the premium tune. Ill try another tune n the morning.
Posted: Sun Jun 14, 2015 7:39 pm
by kellyfj10
heath t wrote:Mine has a bad hesitation at part throttle. Its spitting and sputtering. Between 1/4-1/2 throttle, the truck lurches and sputters. No backfiring, just acts like it loses all throtle or fuel fo ra spilit second. It does it constantly and consistantly at part throttle. Im also currently running the premium tune. Ill try another tune n the morning.
Did you try a different tune?
Posted: Mon Jun 15, 2015 6:16 pm
by juangorena
today, customer walking home issue , after 5 o 6 minutes I has a power loss issue , the truck idle and didn't accelerate , I couldn't go over 3-5 mph it was really annoying since I didn't had the programmer on hand, I left it at home , I was using the performance tune, I restore to original back up and everything went normal , now I;m afraid to have to abandon again my truck in the middle of the traffic since it is not capable to move with the performance tune installed , when do you release a revised version? I had installed the f revision
2015 4x4 3.5L eco f150
