i have a customer who've done a custom tune by me couple of months ago
then he installed full exhaust and want another custom tune
the problem here is when i plug it to the laptop and oped the DS the message above appears, even when i plug it back to the car in order to return original backup.
the car is Dodge Charger R/T 2014
the version of trinity is 1r13c for DCX
the part number is 6QKLZBD-4
ECKS Fatal Error !!!!
Re: ECKS Fatal Error !!!!
try erasing the custom tune off the tool through the options menu.
riyadhtuner
i did and worked perfect
until i retune the car another issue comes
"unable to write 1024 bytes"
not kidding i tried to retune 3 times
here are the files
what i do initially is to adjust fuel on 93 Pref tune, i discovered that Trinity wouldn't accept any adjusted files especially with this particular car !!
here are the files
- PCM_68212715AD_Perf_93oct_modified.drg
- (3.25 KiB) Downloaded 183 times
- 3.drg
- (105.69 KiB) Downloaded 149 times
- 2.drg
- (105.7 KiB) Downloaded 158 times
- 1.drg
- (105.68 KiB) Downloaded 188 times
nescafe4all
Facing the same problem
export a new backup to replace the one you have and iit should resolve the issue.
