'13 Challenger R/T - DCX won't load tune
Posted: Thu Jul 02, 2015 4:31 am
I received the DCX today (bought from Diablosport), updated it from my computer per the instructions, tried to load the 91 octane tune into my car and everything seemed to be going fine until the key cycle part of the process. Mid-way through that process the car says the key fob can not be detected. I end up having to unplug the tuner and try again. It then says that it needs to reload the stock tune, but it runs into the same issue. I've tried this 8 times today, and every time the same issue. I ended up with a U0141 code. After I unplug the tuner, if I let the car sit for a few minutes I can finally start it again, but at this point I can neither load the 91 tune nor load back in the stock tune. I had the In-Tune on my 08 charger with no issues, and expected the same with this tuner for the challenger. Please help. Info.xml code is attached.
P.S. My car has the push button start, which I would cycle between Run (without starting the car) and Off. My understanding is that for the '13 challenger the push button cannot be popped out to use the key the way that they could in the earlier challengers.
