Your Vehicle needs an update...
I have an unmarried Predator with a Predator tune on the vehicle. Since I cannot make changes without it being married, my predator just does nothing. When I connect it to the computer it connects, but doesn't give me the option for the calibration. Is there a way someone can send me a original back up of a 2006 SRT8 Charger so this tool can have a purpose again? Thanks.
Re: Your Vehicle needs an update...
I dont seem to follow, whats the issue exactly?
Are you trying to access the tune menu while connected to a PC?
Long story short, My car has a Predator tune on it, I lost my original predator in a fire a few years ago. The predator says my vehicle needs an update. When I connect the predator to the computer it does not give me an option for a calibration update. I've tried on Windows XP, then on Windows 7 both rendering ineffective. My question is, is there a way I can have the original tune emailed to me then I can install it to the predator then upload it to my car, so I can then upload the predator tune and make changes.
Don't know if this will help, but this is what DS Downloader says under "Tool Info"
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM3 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '2130741557'.
Part number = 'u7135'.
CROM version = 'u7135-9r30 01/12/2012 04:19:44 PM boot3'.
Vehicle VIN = '2B3KA73W96H421946'.
Vehicle Calibration = ''.
Original backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool SUPPORTS multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 0
Marriage VIN : 2B3KA73W96H421946
Tool ID :
Desc :
Multi ECU Tuning : 0
Server:
Tool ID :
Desc :
Server:
the tool is not requesting an update according to dsdl, make sure you click agree to the cal update request in the vehicle.
