Rev limiter on 2015 Dodge Challenger Scat Pack
Posted: Tue Jul 07, 2015 8:19 pm
by sizzle06
I installed the pcm today and loaded the tune with no problems but when i was adjusting the rev limiter,it says you can only go up to 600,is this maybe just a glitch? I wanted to raise it a little bit more than stock.
Sam
Re: Rev limiter on 2015 Dodge Challenger Scat Pack
Posted: Wed Jul 08, 2015 11:06 am
by sizzle06
I also didnt see any shift point options. Is there a update for that?
Posted: Wed Jul 08, 2015 11:43 am
by jstoltz1234
sizzle06 wrote:I installed the pcm today and loaded the tune with no problems but when i was adjusting the rev limiter,it says you can only go up to 600,is this maybe just a glitch? I wanted to raise it a little bit more than stock.
Sam
Sam I ran into the same problem and maxed mine out with the visual and it appeared to raise the limit but said 600... weird. Pushed the car pretty hard yesterday after the tune and didn't seem to hit the rev limiter like I did before. I have a manual so the autos might be different. I wouldn't go over 6400 with a stock engine anyway... On another note a tip I found from other 6.4 owners if you use octane booster and run the car 3% rich at WOT on all RPM levels from the diablo modify parameters settings the car really wakes up.. Not for ones trying to save gas but we wouldn't have this type of car for gas mileage (at least not me) I need to log data to be sure it's not retarding timing but the feel at WOT as opposed to the stock 93 tune is noticeable... Try it and see what you think.. You can always go back.. These tuners make this type of stuff so much fun.. Thank you Diablo!
Posted: Wed Jul 08, 2015 12:05 pm
the rev limit is +/- 600 rpm, from the stock setting, so + 600 raises it to 600 RPM over the stock rev limiter.
No shift control for these cars currently.'
Posted: Wed Jul 08, 2015 1:22 pm
by sizzle06
Oh ok,thanks Mike,i was just use to the settings when i had my 2012 charger srt8.
