My power went out on my 2001 Chevrolet Camaro Z28 predator tuner. Found out a wire became unconnected from the chip in the OBDII connection case. CONFUSED. The gray wire is soddered to the brown connection spot and the white wire is soddered to the blue connection spot. A green wire is unattached and appears to have been previously soddered to the red connection spot....is this correct? Also the brown wire in the pic I attached appears to have never been soddered to anything, is this true as well?
Thanks, Alex
Sorry for the super big attachment!
OBDII wire connector help
- IMG_1418.JPG (1.61 MiB) Viewed 3786 times
Red 2001 Chevrolet Camaro Z28, SLP intake, SLP Y-pipe, SLP Loud Mouth exhaust, Predator custom tune U7198, BMR suspension components (STB, RB, Adj. PB, Adj. TA, RCA, Eibach Pro-kit
DiabloMatt
Re: OBDII wire connector help
yes... it goes to the red connection spot.
might as well fix that Brown wire too while you're in there, that one's already breaking off too...
Made the connection and it works perfect. Never knew where the brown wire was connected to...no evidence of a sodder break. Looks like it was never connected?
