Need Help Please!!! 06 Mustang GT
Posted: Tue Jul 21, 2015 2:55 am
by dbqking
I need some help I had someone write me mail order tunes for my car and it has been a nightmare since. I was wondering if you guys can look at these tune files and tell me why these tunes cause P0605 AND P060C CODES ALMOST INSTANTLY ! My car has been running a tune since 07 and never had a engine light but I wanted to try these supoosedly new and improved tunes and what a nightmare getting support from the tuner. I will post up original backup last tune written and the new tunes that are code problems every second and causing wrench light on dash.
Re: Need Help Please!!! 06 Mustang GT
Posted: Tue Jul 21, 2015 9:20 am
by DiabloMatt
could you list what modifications your car has and i'll get you taken care of.
Posted: Tue Jul 21, 2015 12:25 pm
by dbqking
Computer Code: GYX1
Device: Diablosport Predator (2005-2006 V6/GT)
Tune Type: 2005-2009 Mustang
Performance V2 Tune Octane: 93
Race V2 Tune Octane: 93
Model Year: 2006
Model Type: GT
Engine Size: 4.6
Airbox: C&L Street
Cold Air Kit: Cold Air
Throttle Body: Stock
Charge Motion Control Valve Deletes: No
Fuel Pump: Stock
Camshaft: Stock
Header Type: Short Tube Headers
Headers: BBK
Off-Road Exhaust: No
H/X Pipe: Magnaflow
Catback: Flowmaster
Thermostat: Stock
Gear Ratio: 4.10
Rear Tire Size: 255/45/18
Posted: Tue Jul 21, 2015 12:32 pm
by dbqking
If you can please just make the 93r and 93p tune work with my car it would be easier cause supposedly those tunes are written to my car but they just can't to get them to run the car without codes popping up. Thank You! And if you could please let me know what is wrong cause I have been waiting 14 days and counting.............
Posted: Tue Jul 21, 2015 1:06 pm
by DiabloMatt
i suggest you use mine and try that one as i personally am not fond of what is going on in the other tunes....BUT i did fix the other tunes as well to not throw codes. so i posted all 3. you can use which ever you like/runs good
please report back and let me know
Posted: Tue Jul 21, 2015 1:37 pm
by dbqking
I will definitely only use your tunes and thank you very much! Can I ask should that tune be a little stronger than the tune I was using? And also what is it about those tunes that concerns you just curious.I will let you know how I make out.
Posted: Tue Jul 21, 2015 2:03 pm
by DiabloMatt
mine should be a bit better than your old one. i made some updates on it and also made sure to accommodate for the 4.10 gears.
as far as the other ones. Its not like they are dangerous or anything. its kinda of hard to explain but there is several different approaches to arriving at the same point. they choose to go the long and complicated route and it just wasn't necessary. The codes were just something simple that they apparently over looked. best way i can put it.
Posted: Wed Jul 22, 2015 9:27 pm
by dbqking
All of them work perfectly fine! Thank you so much! Now time to give it shot down the track!
Posted: Thu Jul 23, 2015 9:25 am
by DiabloMatt
let me know how it does
