registration issues
registration issues
hi icant register the intune, appears this message SMTP ERROR,
Re: registration issues
save this to the intune drive and let it import the file to register it.
- registration.itf
- (859 Bytes) Downloaded 439 times
its´still appears the same error
ok, this its how the intune starts to fail, yesterday i made all the procedure before the installation on the car, so when i connected the intune on the car srt4 2003( a friends car) everything seemed to be fine, they intune recognize the ecu and i made all the steps to instal the diablo tune, and modify some parameters, the installation began saving the stock program, and the install the diablo tune, suddenly the intune starts fail, and put the intune in recovery mode,and the recovery mode fail too. since that happens i cant update the intune, the weird thing its that the car runs normal, but the intun still is in recovery mode.
previously i installed another intune device on my 2004 srt4 with no issues, i need help, its driving me crazy
- 20150729_104723.jpg (1.79 MiB) Viewed 8890 times
this appears on the intune
- 20150729_134235.jpg (985.04 KiB) Viewed 8889 times
run the updater program and let it update the tool.
Bump, i need to make the intune works, its brand new, never used in other cars
mikel wrote:run the updater program and let it update the tool.
i give up, can you do it for me please, i ve tried all that you said and still cant registrer the intune, this its the serial number
InTune part I-1000
bar code
18122 44545
other bar code
J2H9W8F
InTune part I-1000
bar code
18122 44545
other bar code
J2H9W8F
post the current info.xml file please.
you have not loaded the registration file I provided yet. that needs to be done first.
i all ready drag and drop the registration file to the (F) drive, run the intune.exe from the (E) drive and still apears the smtp error on the registration menu
