Windows 10 problems
beachking2000
Windows 10 problems
Post by beachking2000 »
Having issues with dataviewer not connecting to tool in windows 10.
Re: Windows 10 problems
working on a fix.
Here you go.
DataViewer_3.3.0.16.exe
(15.32 MiB) Downloaded 2692 times
beachking2000
works thanks.
Dragon23
Post by Dragon23 »
So should I select to fix C++ or repair still not connecting
make sure the driver is installed?
This software has been tested quite a bit and works fine with win10.
brod10
Post by brod10 »
Would this also work on the predator?
zaktech
Post by zaktech »
Data Viewer still hangs on "Searching for a connected tool" (3.3.0.16)
uninstalled / reinstalled same problem
Win 10 sees the I2 without and problems
zaktech
Post by zaktech »
Device manager reports the following for the I2
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
uninstall the current drivers through the device manager then load the driver here:
http://installers.diablosport.com/softw ... er_2.5.exe
zaktech
Post by zaktech »
Already done that three times.
Downloaded the usb 2.5 drivers from your link, but can only test tomorrow, but I see the digital signature date is the same as I have previously used. (22 October 2015)
Return to “DataViewer/DV2”
