Intune burned in a fire. What are my options
Posted: Sun Aug 09, 2015 7:05 pm
by dpb119
My intune burned in a housefire,but the truck is still tuned. Can i get a replacement that Will work with the installed tune.
Re: Intune burned in a fire. What are my options
Posted: Mon Aug 10, 2015 10:34 am
a replacement will allow us to get it all back to stock generally, what vehicle is it specifically?
Posted: Mon Aug 10, 2015 11:44 am
by dpb119
Its a 2014 Silverado LTZ 6.2L
Posted: Mon Aug 10, 2015 11:51 am
do you by chance have copies of the backups from the old tool?
Posted: Mon Aug 10, 2015 12:21 pm
by dpb119
Sadly, i lost the laptop. I do have the programmer, but the case is melted. Is it possible to retrieve anything from that?
Posted: Mon Aug 10, 2015 2:33 pm
plug it into usb and see if there are files on the drive.
Posted: Mon Aug 10, 2015 3:54 pm
by dpb119
When i get home, ill see if i can find a cae that will work. That was butned up. The port looks a little disfigured, but ill see how it goes and let you know.
Posted: Fri Aug 21, 2015 7:37 pm
by dpb119
I was able to recover intune files from the burned laptop, but I can't tell what is what. Would it do any good to send you any of these. Some may be from my old 2010 6.2L
Update: I found a usb cable that had a matching plug. Plugged it in, but the pc didn't pick up the USB. The screen comes on white. Have no idea if it is booting when i do this.
Posted: Mon Aug 24, 2015 9:03 am
by garrett
sounds like the tool is not functioning, and will be impossible to retrieve files off of it.
Posted: Mon Aug 24, 2015 10:46 am
by dpb119
What are my options? Can a new unit be set up to work on my truck? Someone should have a stock file that could be used as a stock base.
Attached is a clip some files I found from the hard drive on the burned laptop.
Posted: Mon Aug 24, 2015 11:22 am
by dpb119
the unit powers on, but there is no screen.
