Predator u7145
SuperDiabloS197
Predator u7145
I have a 2007 GT I recently bought from RPM outlet the Diablo Tuner with C&L Kit. I installed it, but in the option give to performance tune for C&L. There is only two options Street C&L(91 Octane) or Firm Shift(93 octane). Is there a way to get the Street tune for C&L with 93 octane without havin to get the Firm Shift. By the way Is it normal that when you up load the Firm Shift tune the Traction control is disable? Thank you for your help
RE: Predator u7145
If you want to set up the C&L 91 tune for use with 93 octane, use the global spark adder to add 2* of timing to the tune.
The traction control disable is normal.
