I was just wondering what everyone else has their values setup for the AEM UEGO Inline AFR Controller.
Here is what I have mine set up as:
Options
Analog Input Configuration
Add a new Parameter
"AFR"
Input Channel 1
Percent
Lower Bound: 7.312
Upper Bound: 19.164
AEM UEGO Inline AFR Setup
Re: AEM UEGO Inline AFR Setup
I had AJ of HEMITUNER Performance calibrate my AEM Inline AFR on a dyno and these are the settings he came back with:
Lower Bound: 8.000
Upper Bound: 18.000
He said it still reads a little off from what the dyno reads out of the tail pipe but so do the Hellcat factory wideband sensors.
Lower Bound: 8.000
Upper Bound: 18.000
tail pipe sniffer isn't as accurate as a wideband properly installed up front in the collectors anyway..
your wideband, installed in the collector up front, will be more accurate than the tail-pipe sniffer..
