abs and brake light
bob34787
abs and brake light
Post by bob34787 »
just installed tune and abs and brake light remain on while driving, is this normal?
RE: abs and brake light
Only normal if you have ESP disabled. Did you do that in the quick adjust?
bob34787
Post by bob34787 »
yes I turned off esp.
then it is normal....keep in mind that your ABS will NOT function with ESP disabled.
bob34787
Post by bob34787 »
dumped my flaspaq for the predator, you have a great product here, it does what its supposed to unlike my previous tuner. What would you suggest as a rev. limit on the 5.7 I do not want to hurt it too much. I realize dodge has set it at 5800 but will 6100-6200 be in order?
I'd select the raised shift point option, and leave the rev limiter alone, as it is raised in the tunes to take advantage of the higher shift points.
bob34787
Post by bob34787 »
Thank you
