2012 Durango 3.6L P0128 code
I have a dodge durango 3.6L with all the typical mod air and exhaust, throttle spacer, and ripp 180 thermo., and your intune dcx. Running the diablo tune woke the durango up. But the problem i am having is that it keeps throwing the code p0128. I reset it and maybe a few days pass and it does it again. Can you help clear the code so it doesnt happen again.
Re: 2012 Durango 3.6L P0128 code
post the tunes from the tunes folder on the intune drive.
Last Tune
fix attached.
I uploaded the fix you sent to my Durango, but the check engine light still came on a few days later. Today I was looking at the adjustable perimeters and my in tune got stuck in recovery mode. What should I do?
what was the code that came up?
if it is in recovery allow it to restore please.
SUPPORT: I emailed you directly from the Intune app about this same 180 degree P0128 issue happening on a 2013 JK Wrangler, could you please have someone respond??
