mikel wrote:save this to the i2 drive, let the tool import it, then go to the truck and it should prompt you to load the update then let you tune it.
I moved the file to the tuner and hooked it up to the vehicle. No dice: got the same message VEHICLE NOT SUPPORTED. disconnected and hooked up back to the computer. the same update has downloaded (in the past 5 days i must have downloaded it 5,000 times), got it installed, and hooked back to the truck - NO RESULTS. Disconnected again and hooked back to the computer and opened the files on the tuner. clicked on the name of the update file of the tuner (after another download) and changed the name by removing the last 2 characters ('ae') in the name. Hooked back to the truck, got a message 'Uploading uncompressed file' (same message as before), but then I got something new, 'Update Calibration File of the Vehicle?" I said, 'Yes' and it started doing something and then I saw the message, "Calibration for VIN (my truck vin number) has been Updated" (!!!). This is the first time I see this ...
Whew ... hooked the *&&^% tuner back to the RAM for the umpteenth time, clicked on 'TUNE VEHICLE' and saw the Calibration Update being written to the memory.
You guys should fire all your Support Consultants and hire me on a part time basis. I will not charge you too much, I promise.
