I want to disable iDFSO please add support!
Is it possible you will be adding support to disable iDFSO in Chrysler vehicles? I can feel it kicking in and it bugs me!!
Re: I want to disable iDFSO please ad support!
decel fuel cut off?
What vehicle?
What vehicle?
Yes it's the fuel cut off. I have a 2011 Durango with 5.7L and I can feel the drag when I let off the gas. It's real annoying
post the tune files.
What tune files?? I'm asking if you will ever add the ability to disable it through your tuner
No, not through the tuner.
Ok. Do you know of any other way to disable it?
Yes, post the tune files from the tool, and I will do it for you
Sweet!! Can you tell me where to find the file? I looked in the "tune" folder but it is empty...
Re: I want to disable iDFSO please add support!
you have to load the tune to your vehicle, then post the files from the tunes folder.
here are the files... not sure if you needed both or just the last tune written... please edit the tune to remove the decel fuel shutoff. thanks!
Mikel can you please edit this for me?? I want the mes with it this weekend!
give this a shot and met me know.
Thank you! Do I load it to my tunes folder and treat it as a custome tune?
Also, is this a modified version of the caned 91oct tune or a modified stock tune?
Hopefully it's the caned tune so that I still have the option to return the vehicle to stock
its the tune you posted with jjust that change, save it to the intune drive and the tool will import it.
