ST knock 96 deg?
Posted: Sat Nov 21, 2015 10:39 am
by stroudtom
I have a 08 Dodge SRT4 Caliber that I bought recently and a Intune from my previous SRT Neon that I sold. I decided to use the Intune as a scan tool for the time being since I don't have a wide band installed yet. Just wanted to look at the default PIDS on the logging option. The standard outputs look normal except that ST knock of 96 deg. It just shows that value all the time. Thought that was odd but maybe cause I haven't installed a DS tune yet. Then I saw a individual on SRTcaliber forums post questions about the same values with his Intune. So I thought I would ask here as to what that value represents.
Tom
Re: ST knock 96 deg?
Posted: Mon Nov 23, 2015 1:09 pm
can you record a log then post it here?
Posted: Mon Nov 23, 2015 10:45 pm
by stroudtom
mikel wrote:can you record a log then post it here?
Will the intune store a log if it is not married to the vehicle?
Tom
Posted: Tue Nov 24, 2015 9:46 am
by sohfast94
mmmmm seems odd. MAke sure the tool is fully updated and then once you're done with all that go to scan tool - datalogging - configure - restore default pids
Then try again. Should be good then. Caliber uses a set of pids that are unique to it so shouldn't have this issue.
Posted: Tue Nov 24, 2015 10:18 am
Tom
yes..
Posted: Sun Nov 29, 2015 7:29 pm
by stroudtom
sohfast94 wrote:mmmmm seems odd. MAke sure the tool is fully updated and then once you're done with all that go to scan tool - datalogging - configure - restore default pids
Tried the PID restore and still showing 96 deg. Odd also the data viewer only shows external PIDS:AFR, Analog 1 and Batt Volts.
Posted: Sun Nov 29, 2015 7:30 pm
by stroudtom
Posted: Mon Nov 30, 2015 11:27 am
by sohfast94
Update your dataviewer 8)
https://www.dropbox.com/s/35fpvbqo5guaz ... 7.exe?dl=0
It'll show up fine then.
Posted: Mon Nov 30, 2015 9:23 pm
by stroudtom
sohfast94 wrote:Update your dataviewer 8)
Thanks Brian, the PIDS look fine with that update. Does this mean the Intune has issues displaying these values in the realtime log mode?
