Intune computer Calibration ID Error
shmigelz
Post by shmigelz »
Hello,
Keep receiving the same error message now every time I plug in the intune to the laptop. Worked fine for the first month and then just?????
Please see the attached picture for the exact error message.
Here is the .xml file
<?xml version="1.0"?>
-<tool_info>
<main svn="8521" sw_rev="1r04i" full_version="InTune-1r04i 08/03/2015 01:32:36 PM"/>
<registration status="1" sn="KUFI0F0-8"/>
<cal_id CM2="23482558, 95406746, 22888290" CM1="24268165, 24274515, 24274513, 24274516" PCM="12656286, 92282771, 92282768, 12643594, 92275084, 92280931, 92280941, 92280936"/>
<restore bc="0" vin="1G1PG5SB5F7229871" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01f" mfr="DCX"/>
<db pid="1r01b" tune="1r02d" mfr="FORD"/>
<db pid="1r01a" tune="1r02q" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="1G1PG5SB5F7229871" oem="GM" calid="12656286, 92282771, 92282768, 12643594, 92275084, 92280931, 92280941, 92280936"/>
<updates count="9"/>
<oem tool_oem="DIABLO"/>
<reg reg="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"/>
</tool_info>
shmigelz
Re: Intune computer Calibration ID Error
Post by shmigelz »
here
info.xml
(2.19 KiB) Downloaded 299 times
any files in the tunes folder?
post them here please.
shmigelz
Post by shmigelz »
here are the files in the tunes folder.
ECM_92282768_LastTuneWritten.grg
(115.06 KiB) Downloaded 320 times
ECM_92282768_BackupDiabloTune.grg
(114.01 KiB) Downloaded 309 times
ECM_92282768_Backup.grg
(114.63 KiB) Downloaded 297 times
shmigelz wrote:here are the files in the tunes folder.
save this to the intune drive and let the tool import it then go to the vehicle and click tune vehicle/write vehicle and let it load the update to set the pcm back to stock.
CTRL_92282768_UPDATE_1G1PG5SB5F7229871.grg
(104.62 KiB) Downloaded 309 times
shmigelz
Post by shmigelz »
Thank-you. I'll try that and let you know if any issues.
