In the right thread this time so will keep this short
HEMIxFEVER
Well got my intune before thanksgiving and had issues trying to write to pcm (cal update) which caused no starting and i tried many of things, so i called today and was told to send the stuff in. So will be doing that tomorrow during my lunch lucky for me my boss deals with ups, and we have boxes laying around.
I went from cant wait to run it to cant wait to sell it
For those that got the pcm back how did yall instill it (i know plug it back in) but did you drive it stock for awhile, or go right into tuning.)
Also the customer service is pretty good in my book, just wish yall were open on Saturday
I am hoping i dont have to worry about this issue once its fixed. Just flash and go as i please.
Re: In the right thread this time so will keep this short
did you ship it yet?
if not I have an update you can try in the meantime.
HEMIxFEVER
No not yet, i planned on boxing it up for lunch.mikel wrote:did you ship it yet?
plug the tool into a pc and load the attached file to the i2 drive.
then, go to the truck, plug it in, and click NO on the recovery and let it go to the main menu, from there, it should import the file you loaded at the PC and update itself.
Once thats done, reboot the tool, and let it try the recovery process again, it should be able to restore the stock tune and recover the vehicle.
HEMIxFEVER
Thanks i will plug the pcm back in and try this on my lunch break hope it worksmikel wrote:plug the tool into a pc and load the attached file to the i2 drive.
EDIT mike thanks for the help, and the update, right now I am at 19% what should I do now after it gets done? try tuning it?
About to try the 93 tune it loaded now its 93 gas
My idle is higher now as well.
sounds good, let me know if all is well
HEMIxFEVER
Will do mikemikel wrote:sounds good, let me know if all is well
HEMIxFEVER
Got a question it says under advance tuning>the first one what is the dialbo tune?
And how do i tell what tune i am running i tried to adjust the throttle % how do I know what tune it used, then i tried flashing the 93 tune again and failed but i had a back up tune and trying it again now it says please wait..
HEMIxFEVER
So I went to advance and flashed the 91 tune like nothing may drop it to 89 it feels like its down on top end some or its holding gears longer idk what's going on there
Is there any major difference between 93 and 91 tunes?
Just tried flashing the 93 tune and it worked.
Here is what i am talking about in my post above this one
Also what does the tow tune do/change
Sorry for the questions and hard to follow post, as time goes on i am figuring stuff out.
diablo tune is the 93 octane tune. Difference between 91 and 93 is a few degrees of timing at WOT.
HEMIxFEVER
Thank you i got a custom tune from hemifever its noticeable differencemikel wrote:diablo tune is the 93 octane tune. Difference between 91 and 93 is a few degrees of timing at WOT.
