I would like to increase throttle response, i am assuming that is what TB (throttle boost) does.
What is a good safe number or is it all a matter of individual feel. will 20% hurt anything?
And what exactly is this parameter changing, adding fuel like a holly carburetor accelerator pump or adjusting the throttle position since it is throttle by wire.
Thank you
Throttle Boost, What exactly does it do?
DiabloMatt
Re: Throttle Boost, What exactly does it do?
benningtonr wrote:I would like to increase throttle response, i am assuming that is what TB (throttle boost) does.
Thank you
20% is a good start. you can adjust as you wish. what is does it make the gas pedal more sensitive. so for example. 20% pedal is really 40% throttle (depending on where its set of course)
benningtonr
okay so it plays with the position and not the fuel curve. cool, thanks i have it at 5% but I have not driven it yet, just set it during a break.
DiabloMatt
benningtonr wrote:okay so it plays with the position and not the fuel curve. cool, thanks i have it at 5% but I have not driven it yet, just set it during a break.
correct it does not effect fuel. 5% is fine. like i said you can adjust it to what you want. we dont let you get too crazy
