PCm calibration
xtremeroller
PCm calibration
I got my inTune i-1000-DCX in today and plugged it into my laptop, it updated. I took it and plugged it into my 2014 Ram 1500 5.7L and it came back with a message that said "PCM calibration for vin# might need an update. Check for calibration update. I plugged it back into my laptop it loaded up to the home screen and nothing. What do I need to do here so I can use my tuner??
Re: PCm calibration
plug it into the pc and let the updater run and it will download the file.
xtremeroller
Re: PCm calibration
I'm still getting the same PCM calibration message
xtremeroller
Re: PCm calibration
Here is the info file
Re: PCm calibration
save this to the intune drive and let the tool import it then go to the vehicle and load the update then you may tune it.
xtremeroller
Re: PCm calibration
Seems to have done the trick. Thank you
Re: PCm calibration
is there a different file for a 2012 durango r/t 5.7 or will this file also work for my vehicle? the instructions for mac users are so vague, once you drag all the files from the disc icon to the drive icon then what do you do with them please send some thorough instructions as im not only new with the diablo product but also not very computer savy...... my tuber just keeps saying pcm calibration needs to be updated
Re: PCm calibration
I have a 2011 RAM 1500 and its saying the same thing. What is the process for a mac user? Here is my info.
challengerguy
Re: PCm calibration
i am getting the same calibration message. Ive plugged it into both a windows and mac based operating system and no updates occur. will send the info file.
DAYTONA2006
Re: PCm calibration
Any way I can get help with my 06 charger. having the same problem
