My new Intune I2 just arravied and I have a few questions.
Frist, when will the WIFI be enabled? This is one of the main reasons I upgraded and all of the forms you nigate the questions.
Two, will custom tunes from Intune work or do I need to have the custom tune adjusted to this tuner?
Upgrade Intune to Intune I2
Re: Upgrade Intune to Intune I2
custom tune should be redone.
wifi cert is pending.
Still pending? Any ETA on wifi?
wifi is close, but still pending.
I still can't register my InTune2. I have sent 2 trouble tickets over the past month and have not received communications. Please advise
what happens when you try?
Please post the info.xml file from the i2 drive.
I get the same screen as most other users with the New I2. Serial not valid, but that is only part of the issue. Well I just tired to register the device again and it allowed me to this time, but when I opened a support ticket I have not received any correspondence back. I have attached the xml file as requested, but I did register the device.
OK, thats all it should have been, you should be all set.
